I’m having a issue with the mapping the GAIN control to the TREMBLE KNOB.
Mapper - Selected Tremble Knob - Pull Down Select GAIN..
Same For Deck 1 & 2
Save As mk1
Select apply
Worked great.. Rebooted, open VDJ, TREMBLE KNOB controlled TREMBLE…
Open Mapper, Selected the TREMBLE KNOB, is set to gain, apply , don’t work.
Tried Mapper - Load - mk1- apply, Still doesn’t work..
Same For Deck 1 & 2
Save As mk1
Select apply
geposted Tue 26 Dec 06 @ 11:37 pm
got the latest mapper
geposted Tue 26 Dec 06 @ 11:38 pm
Yes, Did that yesterday,,, Like I said,, it worked the first time,, The mapper indicates that the treble knob is gain control..
geposted Wed 27 Dec 06 @ 3:52 am
Try delete the mapper INI file, and try again..
geposted Wed 27 Dec 06 @ 3:53 am
O K, I'll Do That..
Thanks
Thanks
geposted Wed 27 Dec 06 @ 3:55 am
Name: Hercules DJC Mapper v4.1.1
Author: djcel - Team -
Sorry,, didn't work
Is this the mapper?
Description:
v4.1: It uses the new Mapper SDK for VirtualDJ v4.1
v4.1.1: some bugs corrected
There is a screenshot on my VDJ blog
Review:
It only works with VirtualDJ v4.1
"djc.dll" folder: VirtualDJ\Plugins\ControlDevice
Be carefull: you can have to use these settings in order to use it
Date added: Mon 16 Oct 06
Last update: Mon 16 Oct 06
Created for VirtualDJ version 4.1
Sorry,, didn't work
Is this the mapper?
Description:
Review:
geposted Wed 27 Dec 06 @ 5:04 am
I uninstalled Hercules update and mapper then reinstalled them.
Still don’t work
Still don’t work
geposted Wed 27 Dec 06 @ 5:49 am
it's because your using the mk2 mapper and not the mk1 as they have different systems
geposted Wed 27 Dec 06 @ 7:18 am
O K.. I'll try this one
Name: Hercules DJC Mapper v4.0 for VirtualDJ v3.4 and v4.0
Description:
Now include a new graphical interface to map the DJ Console 1, DJ Control mp3 & DJ Console MK2:
* You can change the data in live
* You can save/load settings in different files
* You can affect the function effect_slider() on the stick (affect the two opposite button)s
* You can use the jog to move a slider
v3.0:
* Bug on the pitch corrected
* Now include a tray icon with a lot of options for fast change (use left double click to open/close the window)
* Added (Reset, Auto) in the parameters of functions
* Rotary speed for jogs and pitch
v4.0:
Now compatible with VirtualDj v4.0
Review:
The plugin calls "djcmapper.dll" in the VirtualDJ folder. Simply remove it if you don't like the DJC mapper
Not Compatible with 4.1
Date added: Sun 3 Sep 06
Last update: Sun 3 Sep 06
Created for VirtualDJ version 3.4
[Download]
geposted Wed 27 Dec 06 @ 2:49 pm
O Well,, That didn't work...
Whats next??
Whats next??
geposted Wed 27 Dec 06 @ 2:56 pm
