Why would I use ASIO Mode with MK1..
Should I use 44100HZ or 4800Hz
Thanks
Thanks
geposted Wed 27 Dec 06 @ 6:31 am
Better to use 44100Hz but why ASIO with MK1...??
geposted Wed 27 Dec 06 @ 1:57 pm
The option is there. I can activate it..
Should I use it?
geposted Wed 27 Dec 06 @ 3:03 pm
Use 44 ;)
geposted Wed 27 Dec 06 @ 3:55 pm
dj-in-norway wrote :
Use 44 ;)
Thanks , Di I need to use ASIO?
geposted Wed 27 Dec 06 @ 4:04 pm
ASIO is really only needed for low latency when using timecode to control VDJ.
I think you will be better off using WDM drivers with the Hercules console, if you dont have the need for low latency inputs.
geposted Wed 27 Dec 06 @ 4:06 pm
