Hey all,
Ok i have been using vj 4 but it was from my mate and it was a cracked version not good i know. However after 5 hours ( or there abouts) suddenly the music turns into like a tv static noise..... just wondering if anyone knows what could be wrong?
Plus are all cracked versions the same?
Thanks a lot people
Damian
Thanks a lot people
Damian
geposted Wed 27 Dec 06 @ 7:02 pm
We would suggest that you uninstall that version and reinstall the free 20 day demo to evaluate the program
We do not support cracks or questions pertaining to such.
You just need to see the value in the support you will get, the unlimited plug in access and a stable program that won't let you down like the crack did.
So the decision is yours to make, we hope you will consider the alternative and join the party here.
Rick
Rick
geposted Wed 27 Dec 06 @ 7:11 pm
The sound problem has been corrected in the latest pro version.
DJ Mykel
DJ Mykel
geposted Fri 29 Dec 06 @ 8:01 pm
