About the Motherboard:
It will accept all 478 socket Pentium P4 class processors including the extreme edition processors.
It includes the 800FSB, the classic 875P chipset, and plenty of room for ram.
It accepts up to 2gigs of dual channel DDR400 Ram.
It will support a full size optical drive and 2 full size hard drives.
You will receive:
Intel 3.0 GHz (socket 478).
BRAND NEW 1 gig Kingston ValueRAM DDR 400.
ATI Radeon 8500 Series Video Card.
Fresh installation of Windows XP Pro with integrated SP2.
Memorex combo drive CD-RW / DVD-ROM 52x32x52x16x.
80 gig Western Digital hard drive.
250W power supply.
You will be receiving your Shuttle and all original packaging. (Pictures are of actual item)
You will receive your PC with all parts, cabling, IDE cables, manuals, instructional guides, sata cables, and a free 2 disk version of Linux Mandrake operating system that was included with the Shuttle.
This machine has a Northwood P4 processor.
what about dual core?? system two:
System Configuration:
Processor: Intel Pentium D 820 2.8GHZ Dual Core CPU
CPU Fan: Intel Heavy Duty Cooling Fan With Heat Sink
Motherboard: Pc Chips P23G (up to 3.6GHz+ CPU support)
Memory: not included (supports up to 2GB DDR2 or DDR memory)
Video: SIS 256BIt 3D 128mb onboard video plus 8x AGP slot
IDE/SATS: Supports two SATA/SATA2 and four IDE drives
PCI slots: 3 PCI and 1 8x AGP slots
USB: 4 USB 2.0 ports ( 2 back and 2 front ports)
Sound: AC 97 6 channel 5.1 Full duplex sound (onboard)
Network: 10/100 RJ45 onboard network (Ethernet, cable or DSL)
Ports: 1 serial, 1 parallel, 1 microphone jack
Case: Apevia Silver X-Qpack MiNi PC case (front USB& temp control)
Power Supply: 430W ATX power supply
Case Bays: 2 external 5.25", 1 external 3.5" , 2 internal 3.5" bays
Case Fan: (optional)
Software: All driver disks and manuals are included.
System Condition:
All system components are brand new. System is completely assembled and tested.
*This is not a complete system. Some parts such as (hard drive, video card, memory, etc.) need to be added
was gona go rackmount but forbars clubs i think shuttle would be better
You will receive:
250W power supply.
System Condition:
geposted Wed 27 Dec 06 @ 7:46 pm
how large is the video card
sounds great for audio btw :)
geposted Wed 27 Dec 06 @ 7:50 pm
@ sky: i"ll prob change the video card but there both 300 bucks but the second one is barebones(no video card,no hd
geposted Wed 27 Dec 06 @ 7:57 pm
64MB of powerful double data rate (DDR) memory
geposted Wed 27 Dec 06 @ 8:40 pm
i would recomend 128 or higher best
at 512 if u want to video mix
if sound only
then 64 is fine
if sound only
then 64 is fine
geposted Wed 27 Dec 06 @ 8:42 pm
i want video :D
check out this link shuttle pc built to your specs:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ih=012&sspagename=STRK%3AMEWA%3AIT&viewitem=&item=220063390078&rd=1&rd=1#configurator
geposted Wed 27 Dec 06 @ 8:48 pm
id get the last one personaly
256 dual head
or if thats to pricey the second to last
256 dual head
geposted Wed 27 Dec 06 @ 8:50 pm
I would recommend a x16 video card at a minimum and 256 or 512MB ram video card with very fast processors. I'm not so sure that 64MB card would do video mixing very well.
geposted Wed 27 Dec 06 @ 8:51 pm
i see those cards listed in pci express from $119-$140; i guess i now know what type of video card to get (thanks anewsome/skyfxl) Now what about power;pentium 4 or d or northwood p4?;is the dual core prob solved?and i dont know sh!!! about sockets..lol...Thankx again
geposted Wed 27 Dec 06 @ 8:58 pm
v4 is multithreaded on the dual core so it would be good :)
geposted Wed 27 Dec 06 @ 8:59 pm
so i should for get about that first cpu then huh? btw the first cpu is listed untill i asked about dual core..then thats where the specs for the second one start (which they will upgrade for you via the linq i posted.
geposted Wed 27 Dec 06 @ 9:02 pm
get the best core duo you can aford :)
its better than p4
and
the pentium D is pants
its better than p4
and
geposted Wed 27 Dec 06 @ 9:07 pm
K...i'll look some more ... getting myself a late present :D
geposted Wed 27 Dec 06 @ 9:10 pm
