For Me
VDJ4.2r1 Video Transition Doesn’t work With MP3G’s
VDJ4.2 Video Transition Work With MP3G’s
Could some one comfirm this Please?
geposted Fri 29 Dec 06 @ 12:17 am
what settings do you have?
geposted Fri 29 Dec 06 @ 12:19 am
Oops!! Works before 4.0 sorry
what do you mean settings?
geposted Fri 29 Dec 06 @ 12:21 am
I just tried with my online computer and all the driver/patches are update.
Still doesn’t transition with any other effect than fading in and out.
geposted Fri 29 Dec 06 @ 10:57 pm
Are your MP3+G files zipped? this may make a difference?
What transitions aren't working? I can try them here to see if this problem is replicated :D
DJ Mykel
DJ Mykel
geposted Fri 29 Dec 06 @ 11:36 pm
MP3+g zip... As I said.. It works with with versions before 4.0
geposted Fri 29 Dec 06 @ 11:41 pm
Got it
Under settings/video -- video output --- checked use hardware acceleration
That sucked
Thanks
That sucked
Thanks
geposted Sat 30 Dec 06 @ 12:41 am
Ah, didn't think of video acceleration :( Glad you are sorted now tho :D
Mykel
Mykel
geposted Sat 30 Dec 06 @ 4:11 am
