A problem has detected and windows has been shut down to prevent damage to your computer.
The problem seems to be caused be the following file; ati2dvag
I checked disc for eras, defragged, reinstalled VDJ and MK1 software and still got this message.
geposted Fri 29 Dec 06 @ 5:53 pm
The problem driver there is ATI
So try reinstall your ATI drivers, or update to latest version.. They have some pretty new drivers that you might want to use
geposted Fri 29 Dec 06 @ 5:55 pm
\I'll check it out thanks...
I been trying to get conformation that video transition doesn’t work with karaoke (mp3g)..
I went back to earlier VDJ versions and it worked fine..
Could you please confirm this.
Thanks John
Thanks John
geposted Fri 29 Dec 06 @ 6:01 pm
hmm... will try some
geposted Fri 29 Dec 06 @ 6:04 pm
got the latest drivers and direct x?
geposted Fri 29 Dec 06 @ 6:18 pm
OK....
I downloaded DX9c
Trying toinstall window opens
"please e e locaion where you want to place the extracted file"
Ware do I need to place the extracted file.?????
I downloaded DX9c
geposted Fri 29 Dec 06 @ 9:15 pm
You downloaded the full package, you only need the auto updater:
http://www.microsoft.com/windows/directx/default.mspx
geposted Fri 29 Dec 06 @ 9:24 pm
dx9cis the latest??
geposted Fri 29 Dec 06 @ 9:25 pm
What about Windows Media Player,, should hat be updated to?
geposted Fri 29 Dec 06 @ 9:29 pm
check you have all the latest patches
http://update.microsoft.com/windowsupdate/v6/default.aspx?ln=en-us
geposted Fri 29 Dec 06 @ 9:48 pm
