Forum: VirtualDJ Plugins
Topic: Dev-C++
Ok any one got experience with this devTool when building the Mappers? I am able to get a good compile by VDJ sees my DLL, but ignores it. I think it has to do with the EXPORT of the DllGetClassObject function.
Dev-C++ wants to create the def file with the following -
; dlltool --base-file C:\DOCUME~1\Owner\LOCALS~1\Temp/cca02388.base --output-exp DAC2.exp --dllname DAC2.dll --output-def libDAC2.def --no-export-all-symbols --add-stdcall-alias --exclude-symbol=DllMainCRTStartup@12 --def C:\DOCUME~1\Owner\LOCALS~1\Temp/cca02388.def --output-lib libDAC2.a
EXPORTS
DllGetClassObject@12 @ 1
DllGetClassObject = DllGetClassObject@12 @ 2
I need to get Dev-C++ to use _DllGetClassObject@12, but if change it in the def then it over writes at compile.
Thanks for any help!
cstoll
geposted Fri 29 Dec 06 @ 6:26 pm
If you have an answer great, but I switched back to M$ VC++ and have it working now. But still I am interested in any feedback.
cstoll
which SDK? the one for VirtualDJ v4.1 and more ?
Yes, the new SDK
