Can you go to the next track on a live music video? On a hardware player you can bump to the next track. How to do with virtual dj? I only do private gigs and no club gigs.
Thanks
Thanks
geposted Fri 29 Dec 06 @ 10:17 pm
can you please be more specific
and tell us more about what your hoping to achive
if you mean can you control virtual dj with a mixer ?
only if its a midi mixer such as mk2 or nuo4 midi mixer ;)
geposted Fri 29 Dec 06 @ 10:21 pm
You cant by default....
Either you need to make cue points for each track of that huge video file...
Or better, divide that huge video file, into separate tracks... single files.
geposted Fri 29 Dec 06 @ 10:27 pm
I mean like if you were using a home or pro dvd player. When you load a dvd into it it will pull up the track titles. Then you can bump to which ever title that you want. Going to the next track with virtual dj on a live ripped music dvd?
geposted Fri 29 Dec 06 @ 10:28 pm
Which is easier and best? Cue points or seperate tracks-single files? How to do either?
geposted Fri 29 Dec 06 @ 10:34 pm
Single track files is better... As it makes less of a file size to decode into ram...
SmartRipper or similar DVD rippers should be able to rip each track to a file.
geposted Fri 29 Dec 06 @ 10:45 pm
Will dvd decrypter do that?
geposted Fri 29 Dec 06 @ 10:48 pm
no you will need to rip the chapters to video files to some where on your computer
and load them like music
geposted Fri 29 Dec 06 @ 10:49 pm
How do you do that?
geposted Fri 29 Dec 06 @ 10:52 pm
I have ripped them into chapters. How do i rip the chapters into video files now?
Thanks
Thanks
geposted Fri 29 Dec 06 @ 11:00 pm
did you save .vob files to your computer?
geposted Fri 29 Dec 06 @ 11:07 pm
Yes i saved the vob files.
geposted Sat 30 Dec 06 @ 12:51 am
VOB's can be played directly in VDJ
did you make VOBs for each track?
If your ripper dont support that, try SmartRipper.
I know many use that one
geposted Sat 30 Dec 06 @ 12:53 am
geposted Sat 30 Dec 06 @ 12:58 am
I'm sorry, i dont know that program
But maybe someone else does.
If its a one go ripper (for movies, one file, or chapter) it might not work as you want.
Try the DVD ripper that came with VDJ (in your Virtual DJ install folder), or SmartRipper that I know many here use
geposted Sat 30 Dec 06 @ 1:03 am
VDJ Ripper won't rip copyrighted DVDS.
Thanks
Thanks
geposted Sat 30 Dec 06 @ 1:19 am
Will the Smart Ripper do the job like i want it to? To rip the live videos into chapters, then into single track files?
Thanks
Thanks
geposted Sat 30 Dec 06 @ 1:21 am
YEs, I think SmartRipper will do just that
And its free:
http://www.videohelp.com/tools?tool=SmartRipper
And its free:
geposted Sat 30 Dec 06 @ 1:22 am
Thanks
Thanks
i hope you have a licence to use them ...
geposted Sat 30 Dec 06 @ 1:26 am
Thanks for all the help. I will give the smart ripper a whirl. All of my dvds are not live. I also have promo onlys and some other store bought music dvds that are not live. i just wanted to rip the live ones as well as the others.
Thanks again
Thanks again
geposted Sat 30 Dec 06 @ 1:28 am
