hi, has any1 got a control mp3 linked to ther laptop (not pro)
geposted Fri 29 Dec 06 @ 10:20 pm
thousands of users yes;)
geposted Fri 29 Dec 06 @ 10:25 pm
how do u sort ur sound cards out so i can preveiw through headphones, ;)
geposted Fri 29 Dec 06 @ 10:34 pm
any 1???????
geposted Fri 29 Dec 06 @ 11:09 pm
i think we have told you how 3 times now
but here goes again :-)
you need a 4.1 soundcard +
or with virtual dj pro you can use two cards
with a cheap usb card you can preview on one and listen in on another
to listen in just pess the headphone button for the deck you wish to listen 2
geposted Fri 29 Dec 06 @ 11:10 pm
but my external sound card isnt usb it goes in the slot on the side ov my laptop. iv set it to 4.1 and 5.1 but it still dosent work. how cud i set my external soundcard as my main 1? sorry to be a bother, ;)
geposted Fri 29 Dec 06 @ 11:19 pm
what modes can you choose on the sound setup window ?
i belive you can only use the console
you might need pro to be able to use it.
geposted Fri 29 Dec 06 @ 11:22 pm
in my vdj or my soundcard? non in my vjd just able to tick the box with 'use headphones in 4.1' nothing else! and my sound card goes up to 7.1
geposted Fri 29 Dec 06 @ 11:28 pm
could you take a screenshot of the options you have
then upload it and post it here using www.tinypic.com
geposted Fri 29 Dec 06 @ 11:33 pm
not good with that kind of stuff. wot do u want to know like? my soundcard settings or vdj?
geposted Fri 29 Dec 06 @ 11:43 pm
the vdj sound config tab
please take a shot of that for me
aslo what version vdj?
geposted Fri 29 Dec 06 @ 11:45 pm
its 3.1, its just the sound config page but all the pics hav (only avilable in pro)
geposted Fri 29 Dec 06 @ 11:50 pm
alright so you have tried 4.1 with that card? and no luck?
geposted Fri 29 Dec 06 @ 11:52 pm
yeas i have the sound card hooked up and have a one usb sound card for my monitor. its made by creative labs. In the settins you can select the cound card once you install a usb card it allows you to choose the card you select..then you can use thehead phones in the second card. if you get a 4 in and 4 out you use the mixer to listen to the tracks like you would in the club.
geposted Sat 30 Dec 06 @ 2:34 am
