KAM K 110 USB 2 CHANNEL MIXER - http://www.djsuperstore.co.uk/item/dj-mixers/281996-kam-k50-usb-mixer-%A394.95
Could anyone tell me whether I would be able to use this mixer with Virtual DJ, using each USB input and output as a separate channel? Also would I be able to configure TCV or would I need a different sound card?
Cheers
Cheers
geposted Sat 30 Dec 06 @ 7:50 pm
i belive you could use it as a soundcard for external mixing :)
plug the two usbs in and choose dual soundcard mode
and the mixer 2 times :)
but it has no midi control so cant control the software
geposted Sat 30 Dec 06 @ 8:06 pm
Thanks, I've got a BCD2000 at the moment but would prefer to use a separate mixer as I would like to be able to mix live with vinyl, this mixer says it is USB selectable so should hopefully work. Hopefully this will sort some of the problems with the unstable drivers crashing VDJ, even if the BCD2000 stops working as a controller I will hopefully not loose sound altogether.
Cheers for the help
Cheers for the help
geposted Sat 30 Dec 06 @ 9:41 pm
