Hi,
Does anyone have an idiots guide on how to configure the internal soundcard and a PCI one to get the two inputs required for use with TCV's?
If there is a guide in a blog somewhere or a simple guide it would really help me out.
Thanks
J
Thanks
J
geposted Sun 31 Dec 06 @ 7:04 pm
ok choose
Two Soundcards
choose the internal as the right , and the pci as left
then choose two timecodes
go to proformance
choose "autolatency"
then go to the timecode config
play the signal then double click autoconfig :)
should now be at 100%
Two Soundcards
go to proformance
geposted Sun 31 Dec 06 @ 7:07 pm
Thanks - I've tried and the left deck works fine.
When trying the autoconfig on the right deck it comes up with "no timecode signal found".
I have the right on the internal soundcard as suggested.
Do you think my internal soundcard isn't working? I don't know how to check it.
Thanks
J
ps - your posting on controllers was a great guide.
Thanks
J
geposted Sun 31 Dec 06 @ 8:08 pm
ho hum
and its pluged into the line in ?
cables all working?
which card?
cables all working?
which card?
geposted Sun 31 Dec 06 @ 8:16 pm
Make sure you are not using the MIC In for the internal soundcard. VDJ TC requires a Stereo signal - MIC In is MONO.
geposted Sun 31 Dec 06 @ 8:57 pm
Cheers, which colour should I be plugging the cable into?
It is currently in the blue one.
The others are yellow, pink green and black.
Thanks
J
Thanks
J
geposted Sun 31 Dec 06 @ 9:16 pm
should be blue for line in
which card is it?
which card is it?
geposted Mon 01 Jan 07 @ 5:30 pm
Hi,
I've checked with the manual and the blue is the line in.
I can only guess that the internal soundcard isn't working and all the sound is set up to go through to the PCI card.
I don't know how to check if the internal is working so I'm going to get a cheap s/c from PC world tomorrow. They're about £12 and I'm hoping it will help.
Happy New Year.
Thanks
J
Happy New Year.
Thanks
J
geposted Mon 01 Jan 07 @ 6:40 pm
goodluck !
but before you do
autolatency on both cards?
but before you do
geposted Mon 01 Jan 07 @ 6:42 pm
I've got auto latency selected but I'm only seeing one place to select it. Should there be a another place to select for the second card then?
geposted Mon 01 Jan 07 @ 8:20 pm
na just one , was worth a shot :)
could you post a screenshot of your wavform on control pannel
using www.tinypic.com
to upload and get bb code
geposted Mon 01 Jan 07 @ 8:27 pm
I'm not sure what you mean by wavform but here is my best idea!
http://i14.tinypic.com/2n9xftt.jpg
Let me know if this is wrong and I'll do it again.
Cheers
J
Cheers
J
geposted Mon 01 Jan 07 @ 9:18 pm
on the time code options window
the green and red lines
geposted Mon 01 Jan 07 @ 9:21 pm
got 3 shots for you.
http://i18.tinypic.com/346bajm.jpg
http://i11.tinypic.com/2w69jzq.jpg
http://i13.tinypic.com/3z6we3k.jpg
Thanks
J
geposted Mon 01 Jan 07 @ 9:41 pm
try on
soundcard
choose dual card :)
and your two cards
see what happens
soundcard
choose dual card :)
and your two cards
see what happens
geposted Mon 01 Jan 07 @ 9:46 pm
Got another pic for you!
I can only select ASIO under the soundcard option
http://i17.tinypic.com/4drexxj.jpg
geposted Mon 01 Jan 07 @ 10:04 pm
are you using 3.4?
geposted Mon 01 Jan 07 @ 10:07 pm
nope
4.2r1
4.2r1
geposted Mon 01 Jan 07 @ 10:18 pm
That looks like 3.4 to me unless you have the old skin on 4.2.
geposted Tue 02 Jan 07 @ 6:42 am
Thats defo 4.x version of VDJ ;) look at the setup window....
But input AND output are at SAME channel 3/4
That wont work!
That wont work!
geposted Tue 02 Jan 07 @ 7:05 am
