Is there any chance that VDJ will support PCDJ's UDJ-1 headphones? The are usb headphones that allow cueing with their software. It comes with PCDJ BLUE VRM. Those headphones would be a nice way to practice using VDJ, if supported, on a laptop when away from one's DJ equipment.
geposted Thu 04 Jan 07 @ 4:06 pm
its just a usb 5.1 soundcard ;)
should work fine like any other card
unless they have been cheeky so and so's and locked it to their software only
geposted Thu 04 Jan 07 @ 4:25 pm
I wouldn't want to pay for a set and be disappointed. lol Maybe someone else out there knows for sure. Thanks, skyfxl.
geposted Thu 04 Jan 07 @ 4:49 pm
il try and blag some info of pcdj ;)
i like to spy on their support hehe
geposted Thu 04 Jan 07 @ 4:53 pm
5.1? ... O_o
They are headphones with an integrated soundcard, so you can use them with VDJ. You would have to select "2 cards" option.
Or so it seems..
(http://www.accentmusic.com/details.php?productID=72746)
Or so it seems..
geposted Thu 04 Jan 07 @ 5:05 pm
Thanks Unforgiven.
geposted Thu 04 Jan 07 @ 5:21 pm
Works in any dj software...
BUT, I wouldnt get it if I where you...
Headset break easily, and when broken, you loose your soundcard..
A lot more inexpensive to get a external surroundcard, and plug any headset to that
geposted Thu 04 Jan 07 @ 6:22 pm
The_Unforgiven wrote :
5.1? ... O_o
Or so it seems..
Or so it seems..
its glued together
geposted Thu 04 Jan 07 @ 6:34 pm
