right, i purchased a new laptop in may 2006, and got what I thought was a fairly good video card, should do the job etc, anyhow its the nVidia GeForce Go 7300 w/Turbocache.
Obviously not good enough for video on vdj.
Now ive been thinkin of gttin a new laptop, but cant really spend over £800, but might go a bit higher if i can get something suitable for vdj video mixing.
Anyhow, has anyone got any advice or know of any good deals on decent laptops.
Maybe i'm asking for too much for £800, and if i am i will have to wait and save up.
If you can't think of a laptop under £800, then if you could post me the cheapest u can find, to do half decent video mixing.
Thanks
Adam
Thanks
Adam
geposted Fri 05 Jan 07 @ 12:28 pm
for good cards check in the general forum for "video card ranking"
and check my blog for what to look for
regards
Simon
regards
Simon
geposted Fri 05 Jan 07 @ 12:46 pm
yes i've had a good look at your blog, its very useful, and that video cards post, the thing i'm aving problems with, is finding laptops with these cards.
I was wondering if anyone knew of any good retailers for laptops with good video cars and decent prices.
Excellent info on the blog by the way skyfxl, what comptia courses are u doing? how much do they cost? i was thinking of doing something similar.
geposted Fri 05 Jan 07 @ 1:51 pm
it might be better to choose a website/shop that lets you customise your laptop
then you can get the best features and prehaps it would be cheaper aslo :)
im doing compita A+ S+ N+
soon cisco
they usualy cost 600 each
but you can get them for 400 per pair at some collages :)
soon cisco
geposted Fri 05 Jan 07 @ 2:08 pm
geposted Fri 05 Jan 07 @ 10:32 pm
http://www.pcnextday.co.uk/products/ProductDetail.asp?ProductCode=3384-5701
I found this, do you:
1) think it can handle vdj video mixing?
2)know anything about zoostorm laptops and how they perform
3)know anything about pcnextday
thanks
adam
thanks
adam
geposted Sat 06 Jan 07 @ 11:44 am
it should be ok
one with 2 gig of ram and 512mb would be better
tho
dont know much about zoostorm
but pcnextday is trustworthy :)
tho
geposted Sat 06 Jan 07 @ 11:51 am
