Hi,
When I am mixing in my room, i like to sit back and use the sliders on the Hercules mk2 for the volume. Is there a way to disable the jog wheels as I find myself knocking them whilst mixing?
Cheers,
Nick
Cheers,
Nick
geposted Fri 05 Jan 07 @ 5:59 pm
go to remote control uncheck use jogs to scratch in the config minue
geposted Fri 05 Jan 07 @ 6:25 pm
;) thats the one
geposted Fri 05 Jan 07 @ 7:15 pm
uncheck the scratch for jogwheels will not disable the jogwheels, only change behaviour from scratch to nudge.
To disable the jogwheels, use DJ Cel's excellent mapper ;) At the tool download area
geposted Fri 05 Jan 07 @ 8:33 pm
for pro users
for more info on upgrading
discount
discount
geposted Fri 05 Jan 07 @ 8:45 pm
Or as a quick fix you can put duck tape on your jog wheels.
But the best solution is definitaly upgrading to VDJ Pro using the discount for DJ Console users.
geposted Mon 08 Jan 07 @ 1:47 pm
