Hi
i have had some problems with dj mix station 3. I need the plug-in i need is shoutcast. If have tried things but i have failed :~( I have tried lame_ecc and ecc_lame (.dll) and i have downloaded winamp and the dsp plug-in and tried to use to find the .dll file in winamp program file folder and i cannot find it.
If it is easy to do please reply to me!
And i want to do it without having winamp on is it possible ?
Meny Thx
Dj Mj
Meny Thx
Dj Mj
geposted Sat 06 Jan 07 @ 4:30 pm
Its built in radio server in the full pro version of VDJ, and no need for Winamp.
But the Mixstation version you do. Search the forum, someone made a good guide on how to set it up
Or upgrade to pro if you like
geposted Sat 06 Jan 07 @ 4:35 pm
check my blog for config guide :)
