I'm new to this program so I'd need some help with this. I tried the new 4.2 version and I got a problem with it. The older v3.4 didn't have this problem. When I play music and then touch any of the buttons (volume, treble,mid,bass knobs etc etc) I hear strange noise coming out of them. It's hard to explain what kind of sound I mean so I made a little sample of music playing when I move the knobs. I cut the mid sounds intentionally because then the "crumble" noise sounds louder. I use Hercules Dj Control MK2.
http://www.elisanet.fi/alakoski/sample.mp3
Anyone know what causes this? I'd appreciate the help..
geposted Tue 09 Jan 07 @ 4:55 pm
on the options page go to proformance
then lower your proformance tab to fast
and for latency choose "auto"
geposted Tue 09 Jan 07 @ 6:31 pm
I tried that, but didn't work.. But thanks for the effort :(
geposted Tue 09 Jan 07 @ 8:09 pm
what is ur pc spec?
geposted Tue 09 Jan 07 @ 8:18 pm
I've got a 2,6GHz AMD with 1Gb of Memory and I use the Mk2 own soundcard. But hey I figured it out. It stopped when I turned the Safe Mode off. What is the Safe Mode for?
geposted Tue 09 Jan 07 @ 8:47 pm
for cheaper cards i think
geposted Tue 09 Jan 07 @ 9:09 pm
this could work, if u do have it on, turn the overclock and safe mode off, i had the same problem, and i did that and it worked for me, hope that helps
geposted Wed 10 Jan 07 @ 12:50 am
