Hi!
I was about to buy M-Audio Conectiv but since I can try Numark Cue, I decided to give it a go. So, I downloaded the Timecode and burned it as an Audio CD in Nero with the normal setup. I used a female "Y" cable to plug my CDX into Ch.1 of the Fast Track Pro. When I play the record, I see the waveform of the timecode in its config panel, but when I click Autoconfig, it says that no signal was found, check my cables etc... I don't get it, why do I see it, hear it (the loud beep) but it's not recognized...Please help me!
geposted Tue 09 Jan 07 @ 8:28 pm
Oh yeah, I forgot to say that I only got I CDX, so single timecode mode. Thx
geposted Tue 09 Jan 07 @ 8:30 pm
sounds like the tccd is being played too loud by ur cdx try burning @ a lower volume should work then
geposted Tue 09 Jan 07 @ 8:32 pm
I turned down the signal knob of the chan.1 on my Fast Track Pro and did the same thing, should I however try to burn it at a lower db?
geposted Tue 09 Jan 07 @ 8:39 pm
yes burn cds at lower db try 5db steps
find the one that works best :)
geposted Tue 09 Jan 07 @ 8:41 pm
I'm at work right now and a little worried about this, I love the Cue interface, could you tell me if I see the waveforms, does that mean that with a lwoer signal everything should work fine?:)
geposted Tue 09 Jan 07 @ 8:43 pm
that is correct ;)
geposted Tue 09 Jan 07 @ 8:48 pm
Thank you very much for the fast answers, you guys rule! I can't wait to come back home and try it. I'll come back tonight to tell you how it gone. Thanks again!!!
geposted Tue 09 Jan 07 @ 8:52 pm
Hey guys,
It's still doing the same thing, I burned a CD at 75db using mp3 gain instead of the normal 89db.
I hear the loud beep in my headphones (the signal coming from the CD), I see the waveform in the Advanced view of the Timecode setting window, and when I click "Autoconfig", the error msg appears saying no timecode signal found...What should I try now?
And also; I don't get why I hear the signal (loud beep) in my headphones, is it normal? Shouldn't I hear...nothing coming from my sound card?
Thanks for helping
Thanks for helping
geposted Tue 09 Jan 07 @ 11:35 pm
on windows control pannel mute the output of your line in
then you wont hear any of the noise any more :)
geposted Tue 09 Jan 07 @ 11:38 pm
Hehehe ok, I just found this one, thanks:P
But what do I do about my timecoded signal? Man, it's driving me crazy; how should the waveform look for the software to see the timecode signal? Is it supposed to be a plain line? Cause right now I see it as normal waveforms...I don't get how the software "sees" the signal but cannot recognize it.
Help plz!!!:P
Help plz!!!:P
geposted Tue 09 Jan 07 @ 11:43 pm
could you take a screenshot of the timecode waves , and post them here
using tiny pic
get the bb code and il embed it for u.
using tiny pic
geposted Tue 09 Jan 07 @ 11:45 pm
Here it is
http://i120.photobucket.com/albums/o169/patton686/autoconfig.jpg
What do you mean by bb code?
geposted Tue 09 Jan 07 @ 11:53 pm
Any idea Sky?
geposted Wed 10 Jan 07 @ 12:22 am
Man I think I found it;
I turned my signal knob on my Fast Track to maximum, and the software timecode gain to maximum to, and the waveform became green, and the song I was playing began to sound a lot clearer!
I think that with my "Y" splitter, I lost some gain, I'll try to burn an mp3 with more gain and I think I'll have it!!!
geposted Wed 10 Jan 07 @ 12:31 am
