Hi,
the pitch reset problem when switching the TCV control from one deck to the other is still present in VDJ 4.2 using one TCV mode.
Once again, when switching the TCV control from one deck to the other, the pitch value on the deck that just losed the control should remain the same as the last turntable pitch value assigned to it.
Thanks
Thanks
geposted Thu 11 Jan 07 @ 6:19 am
Have you selected in Virtual DJ - Options - Auto pitch reset > Disable?
geposted Thu 11 Jan 07 @ 8:48 am
Yes, I have tried everything , but the same bug as previous version is there even if in the release note it says that it is fixed.
Thanks
Thanks
geposted Thu 11 Jan 07 @ 10:29 pm
