Hi Guys,
So I have the M-Audio Fast Track Pro USB. I have a few questions about it because i'm not sure if what is happening is supposed to be happening and i'm in need of some more gain.
On the back of the box I plug my RCA cables into 1,2,3,4. (2 Stereo Outputs)
On the front of the box, with the cables in the back, are 1 and 2 supposed to work? There is a a button for Inst and Line. When pressed in it's Line when depressed its Inst. There is a gain knob on the left. Same thing for #2. Am I supposed to see "Signal" and is the Gain knobs supposed to work? If so, they aren't. Nothing is happening.
On the front right side of the box is the stereo/mono button and a "Mix" knob and an "Output" knob. I have these turned all the way up (far right). These knobs do adjust the volume.
I'm just wondering if the GAIN knobs on the front are supposed to be working with the RCA cables plugged into the back, or do they only work when a Mic/Inst is plugged in the front.
Thanks for the help and clarafication.
geposted Thu 18 Jan 07 @ 11:54 pm
