I made a mix. During the mix everything sounded fine. I felt good doing it. When I went back to listen to it, it bounces around and the song is just all messed up. What should I try or what can I do?
geposted Fri 19 Jan 07 @ 4:01 am
try lowering your profromance tab on the proformance options and choose autolatency
geposted Fri 19 Jan 07 @ 11:06 am
I looked for it but couldn't find it.
geposted Fri 19 Jan 07 @ 7:26 pm
Click on 'config' (right above on the default skins of 4.2) and then search for the performance tab. You can read all about it in the manual. I like to help you, but if you look at it in the manual you'll make it easier for yourself.
geposted Fri 19 Jan 07 @ 8:30 pm
