Ok so I understand my internal video card is too weak for video but my pc is fine for Audio. As I said before I'm waiting For Numarks Virtual Vynil but I'm trying to get the hardware side out of the way now.
Is there anything I can do to my current laptop so I can play videos correctly Here are the specs.
HP pavillion dv4000
1.8ghz intel centrino not duo
1 gig ram
80 gig hard drive
mobile intel (r) 915gm/gms,910gml express chipset
video bios 1222
Man it sucks because when I bought this laptop I was just going to do audio. But then I found you guys
Anyway thanks for your help
HP pavillion dv4000
1 gig ram
80 gig hard drive
video bios 1222
geposted Fri 19 Jan 07 @ 10:11 pm
Oh yea forgot to say I want to use the tcv option
geposted Fri 19 Jan 07 @ 10:12 pm
You probably will not be able to mix videos properly with this laptop using VDJ or any other video mixing software. The processor is borderline. You'll need a faster processer. The video card is a non-starter so I would save myself the frustration and not even try it. Unless you're able to add fast video usign a fast media card adapter, I'll say you're not going to have much luck mixing high quality videos.
geposted Fri 19 Jan 07 @ 10:37 pm
