Someone please update this awesome transition plug-in for scratch mixing video.
It is currently only compatible with version 3.xx
Loved it then... would love it for version 4...
Should be a simple fix for anyone who can whip these plug-ins out so quick.
Thanks!!!
Thanks!!!
geposted Sat 20 Jan 07 @ 1:16 pm
Have you ever written a plug-in? And the transition to the new 4.x SDK is easier said than done. Also, majority of plug-in don't have their code posted for anyone to download, so if the originator of the plug-in doesn't update it, then it would need to be re-created from scratch.
So again, easier said than done.
geposted Sat 20 Jan 07 @ 6:44 pm
I messed around with adjusting existing plug-ins for version 3.xx. I had a hard time with getting it going. I don't have all the software and knowledge to be successful at it. When version 4 came out and the SDK stuff, I still had trouble. That is why I think anyone who has done this a while can crank this one right out.
It is basically the fade transition with an adjustment to the fade point to be more as a scratch friendly by moving the mid fade point to a tighter point. Kaymyst is the one who did the original one.
geposted Sat 20 Jan 07 @ 11:02 pm
