This may be a current problem I have w/o even knowing it?
What is a screen mismatch, and exactly what problem does it cause
and how does it evoke the problem?
geposted Wed 24 Jan 07 @ 7:49 pm
when the skin is a different size than ur screen
it leads to instability and more resources being used
which inturn increases crashes
geposted Wed 24 Jan 07 @ 9:10 pm
Atre you saying that the computer SCREEN and the second display screen all need be the same as the skin size?
And are ALL skind labelled with their size included?
geposted Thu 25 Jan 07 @ 2:36 pm
say you have a skin at 800X600 running it at 400 x 200 would mess it up because your computer is expecting the same size
so would running a 6000X4000 skin on a 400x600 montitor
* note not actual sizes lol but helps make the point :)
the video screen however can be any size
geposted Thu 25 Jan 07 @ 3:07 pm
Sky,
I see. My real question was:
Should I set both my computer monitor AND the second extended display monitor to an
equivalent resolution as the skin for better overall expected performance?
Second question?
Are all skins given a resolution size on their download site?
Second question?
geposted Thu 25 Jan 07 @ 8:19 pm
as i said the video (second monitor)need not be the same
all skins are marked :)
geposted Thu 25 Jan 07 @ 8:27 pm
Second output should be typically 800x600 -- most projectors work best if you match there capability -- if that's what you are connecting your second output to.
geposted Fri 26 Jan 07 @ 1:39 am
