Can anyone offer any suggestions as to how I can change the jog wheel on my DAC-3 from scratch, to bend or to search the library?
Is this possible with VDJ and where are the setting(s)?
CM
CM
geposted Wed 24 Jan 07 @ 10:10 pm
heya chris grab the dac mapper to change buttons actions :)
http://www.virtualdj.com/addons/tools.html
geposted Wed 24 Jan 07 @ 11:34 pm
My custom DAC-3 mapper plugin has improved jogwheel behaviour (Scratch/pitch bend), file browsing with the jogwheel and also allows you to trigger effects, video mixing/effects and samples directly from the DAC-3:
http://www.virtualdj.com/addons/download.html?addon_id=2401
geposted Thu 25 Jan 07 @ 1:53 am
