i just bought the m-audio 61 key axiom keyboard
it's a beast !!!
i want to do 2 things
1) i want to control the 12 samples ---- i want to map it to trigger temporary samples---for example--just like hitting the (shift + F6) key
i can map for trigger the samples but not temporary--
2) how can i map so i can use the pitch control ? i want to change the pitch of the sample--
i am struggling mightly
thanks in advance
it's a beast !!!
thanks in advance
geposted Sat 27 Jan 07 @ 6:38 am
momentary box must be checked !!!
now tofind out how to change the pitch with the axiom keyboard pitch control???
any ideas are greatly appreciated
thanks
thanks
geposted Sat 27 Jan 07 @ 7:48 am
add a midi action and choose pitch and twidle the knobs and it will work it out for you
geposted Sat 27 Jan 07 @ 12:13 pm
hi skyfxl
i'm dwindling almost everything i can think of and i can't get the pitch to work
i only want to change the pitch on my 12 mapped samples
i go to configue
remote control
midi---configure
then i get lost
first column--do i select pitch?
second column--do i select pitch bend?
***can i map it so i can use the pitch bend on my keyboard?
if you could, can you write out the directions
thanks
i go to configue
remote control
midi---configure
then i get lost
thanks
geposted Sat 27 Jan 07 @ 8:02 pm
