HI
this may be a question that has been asked. I noticed i can save and burn my cd mixes no problem : )) but heres the big one i would love to do my own video mixes and save them but there isnt no program to this is there. I would love to do the same with my video sets when i work and i can use some of the mixes i already created for my video nights : )))
geposted Thu 01 Feb 07 @ 7:28 am
use fraps.com program to record. it's very intuitive and a great recorder for video
geposted Thu 01 Feb 07 @ 8:22 am
You might be able to use camtasia studio or snagit available at www.techsmith.com.
geposted Thu 01 Feb 07 @ 11:37 am
hi guys am VEEERy new to virtual dj. av been great man with pcdj.
My question is how does one angage pitch bending without using the mouse.
i find it quite too cumbersome.
geposted Thu 01 Feb 07 @ 3:52 pm
ok i understan downloading maybe fraps but heres the question should i download somewhere specific of just on my desktop because if i have this how is the possibillity to record : ) thanks
geposted Sat 03 Feb 07 @ 9:49 pm
thanks all :)
geposted Wed 07 Feb 07 @ 2:15 pm
make a keyboard shortcut check my blog for more info
in future aslo please make a new topic if you need help or you might be missed out :(
geposted Wed 07 Feb 07 @ 2:34 pm
fraps will run from any location simply install it
to start recording video on your monitor go to options and choose what to record and make a staring shortcut , then press that to start recording , then stop the video will be rendered and saved in the fraps folder :)
geposted Wed 07 Feb 07 @ 2:40 pm
Is there any way to configure the fraps.com software to record the actual mixes without getting the track being cued.
geposted Fri 09 Feb 07 @ 5:38 am
