I cant get vdj to recognize i tune files i can drag and drop but when i drag it to the deck no buffering!It is there but doesnt load the song.
geposted Thu 19 Aug 04 @ 3:14 pm
You can't read files bought off I-Tunes in VDJ for now. You must convert them to any other supported format.
geposted Thu 19 Aug 04 @ 3:36 pm
I just converted 1500 songs from .wav to mp3 in i tunes howdo i convert back to a format that vdj can read.If i keep converting am i losing sound quality.This may sound lame but i have to work tonight and i haqve no back up for my .wav files now what?
geposted Thu 19 Aug 04 @ 5:17 pm
dude .wav takes to much space ur better off with mp3
geposted Thu 19 Aug 04 @ 6:09 pm
sounds like he converted to aac....which is the itunes default.
geposted Thu 19 Aug 04 @ 6:51 pm
Yep, you should have no problems reading MP3s in VDJ. Now, iTunes sux (or maybe I misunderstand something) in that there is no direct conversion from AANC to MP3.
What I do now is burn the files to a CD in iTunes, then rip that CD to mp3 using CDex. If anyone knows a better way, I'd greatly appreciate the time and CD-Rs saved!
geposted Thu 19 Aug 04 @ 8:51 pm
How do i convert from aac to Mp3?
geposted Thu 19 Aug 04 @ 9:39 pm
Check the net but I think you will have to burn to audio cd then rip that audio cd to mp3.
geposted Thu 19 Aug 04 @ 11:03 pm
Yup!! That's the only way.
geposted Fri 20 Aug 04 @ 12:58 am
Thanks guys
geposted Fri 20 Aug 04 @ 6:18 am
I have two sound cards so that i get a better performance when mixing w/earphones. why is it that when i drag songs from i tunes into VDJ the deck changes.
geposted Wed 05 Jan 05 @ 9:48 pm
First of all, as a trial version user, you shouldn't be able to use 2 sound devices.
2nd of all, the cracked version you are using is quite outdated. Any problems that you have may be either the result of a poor hack job.
geposted Thu 06 Jan 05 @ 1:16 pm
I'm an Atomix user and have been looking at moving over to VDJ. As I buy alot of songs from iTunes, the ability to be able to play the files would be a great help. At present I have to do what is discussed above, but it's a hassle and I'm not sure the quality won't suffer somewhere along the way. Is this in the development pipeline or is it impossible?
Cheers,
Jack.
Cheers,
Jack.
geposted Fri 21 Jan 05 @ 2:05 pm
magix mp3 maker delux should be able to convert... it will turn it into pretty much any format..
geposted Sat 22 Jan 05 @ 9:05 am
it is impossible to listen to protected AAC format bought on i-tunes. if your AAC isn't protected i think dbpoweramp can convert them into mp3. or install the correct codecs for AAC for windows media player and they will work on VDJ
geposted Sat 22 Jan 05 @ 1:36 pm
Oh oh i remember this post .....hehe...never bought anymore itunes....That's is that's all
I got rid of many of those files from August 3 conversions made the sound lose quality.
I noticed it more at the bar than at home(stick with mp3s)
Andre
Andre
geposted Sat 22 Jan 05 @ 4:56 pm
