I have read in this forum that you are aloud to have vitual dj installed on two pcs. Question I have is will I be able to change my license to a future upgrade pc down the line. Let me explain. I currently have a DELL 5100 LAPTOP with 512mb ram and 60gb hardrive running at 5400, the video card is a radeon 7500 which will be to slow for video but should be good enough for audo. I also have recently purchase a desktop pc from hp with enough specs to run video on.
My concern is that I plan on eventually purchase a custom rackmountable rig from DJ rack to replace my laptop. So my question is do I have to wait until I purchase that rig from DJ rack or will I be able to switch my registration from the laptop to the new rig without any conflict?
Ideally I will like to have it install on my HP desktop as well as the new rig from DJ Rack.
Currently I am using the demo and I like what I see so far. I am currently using VDMX and have previously use BPM Studio Pro so I want the next software I buy to hopefully be the last. One of the things I hated about BPM Studio was there lack of customer support. With VDMX I have a contact person whom has been able to walk me through any problems. With Virtual it seems that there is a lot of support via the forum but none available via telephone. Is there a contact in the US that will provide customer support via phone as well as the forum. I really prefer the one to one support instead of having to search the forum on looking it up. I am really not that tech savy. so I need guidance on working through any conflicts that may arise.
DJ Angel S
DJ Angel S
geposted Sun 04 Feb 07 @ 10:14 pm
welcome :)
you can change those 2 computers at any time
and alowed ulimited reinstalls
we aslo have email support here if u need it
contact
unfortunatly there is not phone support at this time however im personaly always happy to chat with people on msn
my email is admin@skyfxmedia.com
add me if you need any help :)
contact
geposted Sun 04 Feb 07 @ 10:54 pm
Sky, I want to thank you for your quick response and will probally be email in the future if I am stuck on a particular subject. I am well aware that you have already extend youself out to previous users in helping them out. I just prefer a phone contact as a back up.
Thanks again for you help.
So If I purchase Virtual after my evaluation how will I go about upgrade and reinstalling it on the new pc.
DJ Angel S
DJ Angel S
geposted Sun 04 Feb 07 @ 10:59 pm
you would go to the program files
C:/programfiles/virtualdj/
take
the 3 files
virtualdjdatabase.xml
virtualdjdatabase(yourname).xml
mp3datbase.txt
then paste them onto the new pc with your music :)
then all of your info will be on your new pc :)
take
the 3 files
mp3datbase.txt
geposted Sun 04 Feb 07 @ 11:58 pm
I recently copied all my xlm databases over to another user, but it did not save my cue points.. any idea's or suggestions?
geposted Mon 05 Feb 07 @ 12:25 pm
rename the file virtualdjdatabase(yourname).xml
from say bob
to your new username this should solve this :)
from say bob
geposted Mon 05 Feb 07 @ 12:27 pm
from say bob
from say bob
Thanks
geposted Fri 09 Feb 07 @ 8:15 am
When you purchase virtual dj via the website what is version of virtual dj is giving to us. I think I may wan't to eventually purchase but I may want 3.4 instead of the 4.2 for now. Until most of the quirks are work out in the 4.2 version.
DJ Angel S
DJ Angel S
geposted Sat 17 Feb 07 @ 1:13 am
there are not any issues in 4.2 which will affect you
but after purchase you can request 3.4 if you have a problem
geposted Sat 17 Feb 07 @ 1:15 am
Thanks Simon
I am trying to figure out this dac problem first before I do purchase. Also, did you get the email I sent you. Can you send me the link for tweak my laptop for virtual dj.
Angel S
Angel S
geposted Sat 17 Feb 07 @ 1:33 am
check my blog for tweaking tips to do that just press my name :)
geposted Sat 17 Feb 07 @ 1:43 am
Simon
I only see tweaks for vista, where is the tweaks for windows xp
Angel S
Angel S
geposted Sat 17 Feb 07 @ 2:12 am
you might need home level clearance to read some parts i was told off for giving to much away =)
check this
http://tweakhound.com/xp/xptweaks/supertweaks1.htm
check this
geposted Sat 17 Feb 07 @ 12:14 pm
Simon,
I am still having problem with my dac 3 working properly on my laptop. It works fine on my desktop. Reading the forum I think someone else had the same problem due to irq comflicts with laptops.
However, in regards to license. When you purchase virtual dj pro do you need uninstall the demo version before installing the pro version.
Also any suggestion on getting this conflict with my laptop not working properly on my laptop. I did all the tweaks recommend and still same result. It only connect properly about 1 out of 10 restarts. Sometime it works sometimes it don't.
(like an almond joy) lol
DJ Angel S
DJ Angel S
geposted Mon 19 Feb 07 @ 11:37 pm
do the usb ports work with other devices?
you can just over install but you need to back up you bd files like i showed you :)
geposted Tue 20 Feb 07 @ 10:32 am
Yes the usb work well for other devices.
DJ Angel S
DJ Angel S
geposted Tue 20 Feb 07 @ 4:04 pm
