Hello, i have a problem with the timecode signal thats played by my CDJ 1000
it looks like this. anyone can help me with this.
thanks
thanks
geposted Mon 05 Feb 07 @ 11:42 pm
screenshot from the signal
http://users.telenet.be/mrlostkey/timecode.jpg
geposted Mon 05 Feb 07 @ 11:47 pm
the singal is to loud take the mp3 file of the timecode and use an audio editing program and reduce the level by 13 db
if you dont have a program try audacity.
then burn a copy and test
geposted Tue 06 Feb 07 @ 2:52 pm
Sky,
2 things,
1) did you mean 13 db?
2) If the timeocde is a .wav or .mp3 do you know if it matters at all?
Thanks.
2 things,
Thanks.
geposted Tue 06 Feb 07 @ 5:31 pm
db my bad
it comes as an mp3 but easy to change :)
geposted Tue 06 Feb 07 @ 6:32 pm
Just turn down the input level on the audio interface..
geposted Tue 06 Feb 07 @ 10:41 pm
when i turn on my line in the signal looks like this
http://users.telent.be/mrlostkey/timecodelijn.jpg
when i turn on the microphone in signal looks like this.
http://users.telent.be/mrlostkey/timecodemicro.jpg
has anyone seen this before?
geposted Wed 07 Feb 07 @ 6:02 pm
sorry, wrong links
http://users.telenet.be/mrlostkey/timecodelijn.jpg
http://users.telenet.be/mrlostkey/timecodemicro.jpg
geposted Wed 07 Feb 07 @ 6:04 pm
what card are you using it looks like the timecode is aslo only reciving half the wave in mono
geposted Wed 07 Feb 07 @ 6:13 pm
Will my onboard realtech AC97 soundcard with 1 input work with the input on my Creative audigy 2 zs for time-coded viynls
geposted Wed 07 Feb 07 @ 7:55 pm
yes choose dual soundcard mode
geposted Wed 07 Feb 07 @ 10:03 pm
