I have the sonique plug-in selected to be used when I don't have a music video playing. I can't get it to change automatically (it runs the same visual everytime it is used for the entire song). It is a real pain to keep opening the effects window and having to select a new visual every 30-45 seconds and for each new song that doesn't have a video. Unless I was misinformed I thought it was supposed to randomly run through the different visuals automatically.....if not, is there a plug-in that will do this?
geposted Tue 06 Feb 07 @ 11:13 pm
Go to the effects section, highlight the Sonique plugin and activate the SLIDESHOW (button) option of the effect. Then slide the first slider for the delay of change - put it about 1/4th from the right.
geposted Wed 07 Feb 07 @ 12:03 am
Stupid me, I thought that was for the "Slideshow" plug-in. Thanks
geposted Wed 07 Feb 07 @ 4:06 am
