ok then..... im thinking of buying one of these consoles. just a few questions before i do.
1 when you buy this console you get virtual dj with the package is it the full version?
2 is this console the only thing i need to use time codded vinyl? apart from decks lol
3 when your using the console can you set the cue point from the console and set the beatlock?
thanks
thanks
geposted Thu 08 Feb 07 @ 12:13 am
1. No it is the Home Version which is a limited version, but you do get a discount to upgrade.
2. No you need a soundcard with Inputs. I am sure someone else can chime in on this as I don't use timecode.
3. I believe the answer is yes.
geposted Fri 09 Feb 07 @ 6:08 am
the HDJ mkII is all you need except your turntables or dj cd players to play in tcd mode, the mk II has two inputs and they can be set as phono or line
geposted Fri 09 Feb 07 @ 7:55 am
