If I order two of these http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=160085086899&fromMakeTrack=true will that eliminate the need to ground my tt's to my pc when I get my delta 1010 lt card? Or would it be better just to ground to my PC? Any input is greatly appreciated, I'll be buying the delta in a couple weeks and I want to make sure I'm prepared for the upgrade (replacing my u46dj);^]
geposted Wed 14 Feb 07 @ 7:01 am
Why are you buying a pre-amp? VDJ has a built in pre-amp option for TCVs. When you get your 1010 just go to the inputs directly and use the VDJ Pre-Amp option in the settings.
geposted Wed 14 Feb 07 @ 8:34 am
OK, what about grounding? Will speaker wire work and how should I connect between the grounding wire and my PC?
geposted Wed 14 Feb 07 @ 3:49 pm
