hi ,im using vdj3.4 came with my mk2 console ,ive bought a shout cast host ,so the first thing is im broadcasting to the sever everythink works great for a bout 15-20mins then vdj keeps freezing lockin up then works then when im draging tunes onto deck a or deck b its takin longer to get the tunes to load by the time its finnished the other tune has nearly finnished ,ive turned off everythin runnin in the background(antivirus,messenger) ive got a gig of ram duo proccessor in a quite powerfull toshiba labtop ,i see also that the memory usage is like 170,000 the labtop gets very hot aswell,, any ideas would be greatful as when your playin live
it shouldnt keep freezing
geposted Wed 21 Feb 07 @ 2:35 pm
http://www.virtualdj.com/forums/60644/Hardware_Technical_Support/_HW_How_to_solve__issues_with_bad_sound__unstable_devices__pops_and_crackles_.html
check for any conflicts and be sure your using the latest version of direct x
http://www.microsoft.com/windows/directx/default.mspx
geposted Wed 21 Feb 07 @ 2:51 pm
