Hi all. I recently upgraded my laptop. I bought a new one.
Toshiba Satellite A135-s4427 . It came with Vista, sad thing is that Vista does not work with my Soundblaster cards so I put XP on the laptop.
I have searched all over and I cannot find any windows xp drivers.
I think Microsoft has take 4 step backwards with this OS.
The short time I used Vista it drove me nuts asking for approval of every click of the mouse.
Anyway
Thanks in advance.
Anyway
Thanks in advance.
geposted Fri 23 Feb 07 @ 2:01 am
I got a toshiba also, and all my drivers can be found in the Dowloads section :
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_home.jsp
geposted Fri 23 Feb 07 @ 6:27 am
try www.driversguide.com
you can dissable that security behaviour on the control pannel of vista
geposted Fri 23 Feb 07 @ 12:33 pm
Thanks but I did say XP drivers for the Atheros wireless lan card.
geposted Fri 23 Feb 07 @ 11:20 pm
yes use drivers guide :)
geposted Fri 23 Feb 07 @ 11:26 pm
http://support.toshiba-tro.de/tools/SatellitePro/spp100/xp/wlesslan-xp-412111i129.zip
That's for the Atheros wireless XP driver. I'm not 100% sure if that one is the same card. But, give it a try.
geposted Sat 24 Feb 07 @ 10:09 pm
This link doesn't work.
geposted Sun 25 Feb 07 @ 5:22 am
I got it to work, thanks very much.
geposted Sun 25 Feb 07 @ 8:01 am
