Forum: Old versions
Topic: Help: Pitch Reset Problem!
Using VDJ 4.2 with TCV
Swapped laptops and now I'm having funnies with pitch reset. Sometimes the pitch resets properly, other times it doesn't, for example I load a track thats 127.7 bpm, and I'm picthing it at -1 to get 128bpm!
Here's my settings:
Auto-pitch match: Disabled
Auto Gain: Always 0db
Auto Pitch-Reset: Enabled
Auto EQ-Reset: Disabled
Auto Cue: Disabled
Auto Headphones: On-Load
Anything I can do?
geposted Tue 06 Mar 07 @ 5:29 pm
This seems to be a bug, this only happens when Auto Headphones: On-Load is set, is this supposed to work like this?
