Topic: @ aol uk customers
hi gang
this is for all my fellow aol user brothers and sisters out there..
aol for the next week of so will be performing line tests
and other maintenance so the network will be slower than usual i have been told by a rep.
you may aslo experiance unusual dissconections at the same times of the day for a couple of days
as this ocurs. You may aslo notice a reducution in dsl strengh, so it is advisable to plug your router into the master socket in your house and not use extensions or the signal may drop off if you use an extention and disconnect regualy look at the dsl light on your modem
if it flickers this means there is a very weak singal plug into the master.
After this period all should be ok again
aslo its worth remembering last time they did this they shortly later anounced they where doubling every ones speed :)
so fingers crossed!
geposted Mon 19 Mar 07 @ 12:31 pm
