Im new to the whole video mixing thing...but love it, my question is, how do I make the transition from one video to the next using my external mixer, here is what I got:
Laptop
TCV
MK2 Sound Card
Everything works great but I can only transition the video using the MK2 Crossfader......I want to do that using my external mixer.
Laptop
TCV
MK2 Sound Card
geposted Wed 21 Mar 07 @ 8:38 pm
You can use the automatic video transition by activating the transition. It will react to the TCV sound.
Otherwise you need a Midi mixer like NUO4
geposted Thu 22 Mar 07 @ 12:40 am
OK Thanks....one other question:
Is there a 2 channel MIDI Mixer, I need one that would fit into my Odyssey case....Just wondering?
Also......how do I perform the suggestion you mentioned?? In video setttings?
geposted Thu 22 Mar 07 @ 2:13 am
You can use this to controll the video fader if your want:
How to convert a USB Joystick to a Video Controller for VDJ
I will very soon also publish another version that doesn't require to take a Joystick/Gamepad appart, so it's even easier to build.
geposted Thu 22 Mar 07 @ 8:40 am
