Hi Guys
Ive got a mk2 and have just picked up some Gemini GX250 speakers. I'm now confused because each speaker takes either a XLR or dual RCA plugs but the Mk2 output is only a single RCA plug per speaker.
Can someone enlighten me as to what speaker cables I need please and where to get them in the UK?
Thanks for your help
Houmous
Houmous
geposted Thu 22 Mar 07 @ 1:10 am
a simple RCA to RCA lead will do fine - the two sockets on the speaker are only there for convenience, if you want to connect a stereo input to them, or want to daisychain it off to another speaker - in other words, the two sockets are wired together, so you only need to use one of them. Maplins sell long RCA (aka phono) cables, or if you are handy with a soldering iron, you can buy the plugs and cable and do it yourself...
geposted Fri 23 Mar 07 @ 6:12 pm
