please can anyone tell me how to deepen voices when using virtual dj. Will appreciate
geposted Thu 22 Mar 07 @ 2:44 pm
try adding more low eq aka base.
geposted Thu 22 Mar 07 @ 11:47 pm
one way to do it is if your using an accapella is just lower the accapella deck's pitch down to the sound your looking for. activate Keylock.
Throw the pitch back up to the desired amount.
when playing it you will keep the vocal at the key you activated.
This works just like the keylock on Numark TTx. If your used to using a pair then you know how effective this keylock really is.
geposted Wed 04 Apr 07 @ 2:44 pm
Perhaps a course of testosterone injections? ;-)
geposted Sat 07 Apr 07 @ 7:49 pm
