Forum: Old versions
Topic: PLz read!!!!!!!!!!!
i have a problem with Virtual DJ. when i goto load a song it just say the song name it doesnt load the song till i start playing it. never had this problem before but i just want to be able to double click a song and it loads it into the Deck so i can mark the Cue or start a song in a different spot if anyone knows of a setting let me now please
geposted Fri 23 Mar 07 @ 3:57 am
I the Config, check your MAX LOAD option -- set it to 15min. If it is disabled you will get the experience that you are seeing.
MAX LOAD Explained -- this option tells VDJ what to load into memory based on the time length of the file. If the time length is less than the setting (15min) then VDJ will load the file into memory and then you can do what you describe which is see the entire track and set cue points, etc. If the track is longer than the setting (15min) then you get the experience you describe, which is VDJ only reads the file direct from the hard drive and you see the track info as it is read by VDJ directly.
Hope this helps.
cstoll
