Can you guyz help me.
I will geth my virtual dj/Maya 44 usb/timecode vinyl later if i know if i can do this things:
-> C
-> C
geposted Fri 23 Mar 07 @ 9:01 pm
Srr wrong button;
Can i use timecode virtual dj and play normal vinyl to.
I dont wanne use Y-Splitters.
Just my MAYA 44 USB -> Turntables in INPUT of MAYA 44 USB and OUTPUT of MAYA 44 USB in my mixxer and than USB to my computer.
I have read that i can use bypass function.
I have download the demo and no function bypass is there
I have found a function timecode_active can i use that?
I just wanne turn with my turntable timecode and normal vinyl to.
Example: I'm playing timecode on deck A i want to change to deck B now not timecode, i use some function ( i dont know what function ) en than puth normal vinyl on the turntable can i mix than those 2 records with virtual dj.
I hope so.
Thx!
I hope so.
Thx!
geposted Fri 23 Mar 07 @ 9:06 pm
