OK - So i like what i see - I've been Dj'ing using PCDJ for a number of years and am looking to change to Virtual DJ but.........
Can someone explain the concepts of creating playlists
I have succesfully created virtual folders but how can i then load those folders back to the playlist. Also what is the sidelist for?
Thanks
Thanks
geposted Sun 25 Mar 07 @ 11:12 am
The sidebar is a way of making a playlist. Drag and drop the songs you wish to play to the sidebar, manage and save. You can also make playlists in winamp, save them and drag them to one of each "deck" in VDJ - the songs inside the playlist winds up on the sidebar. You can finally make the sidebar play and mix the songs without the need of a present DJ - simply press the button that looks like a magic wand (Enable/Disable automatic mixing).
Good luck!
Good luck!
geposted Sun 25 Mar 07 @ 5:52 pm
