Analyze a new file and at the end, right click and select Edit BPM.
A small window appears with the BPM and buttons /2, X2, .
When you click on the button /2 or X2 the BPM does not change.
geposted Mon 06 Sep 04 @ 9:13 pm
noticed that too. however, although the value doesn't change in the text field of the dialog box, when you click ok it does change in the track list.
geposted Mon 20 Sep 04 @ 9:13 pm
did you ever get that problem fixed... i am having the same issue even after reformatting
geposted Sun 20 Feb 05 @ 7:33 pm
it change!!! it's only a refresh problem!!!
make this operation:
1)edit bpm of the track that you wont...
2)press /2 or x2 and ok
3)click on a track on browser and see the bmp will change
geposted Sun 20 Feb 05 @ 11:33 pm
