i'm tring to time strectch my song so i can chop and screw.
geposted Tue 27 Mar 07 @ 3:28 pm
now integrated in the skin
it's the little (pad)lock icon
usually at the bottom of the pitch control
or sometimes close to the deck(turntable)
depending on the skin you use
geposted Tue 27 Mar 07 @ 4:31 pm
i'm using the old skin from VDJ 3.4
so you you said it's a icon that looks like a pad under the pitch control?
would it be the same for the 3.4 skin?
PAD???
PAD???
geposted Tue 27 Mar 07 @ 5:08 pm
it looks different in different skins
padlock, MT, etc
But the easiest way would be to make a keyboard shortcut to engage the keylock... ;)
padlock, MT, etc
geposted Tue 27 Mar 07 @ 9:31 pm
