I am Currently using a Toshiba laptop with
Processor Type Intel Pentium Core Duo T2060
Processor speed 1600 mhz
Memory Size 1024 mb
VISTA Home
I have an Audigy 2 ZS for notebook. I use the Audigy to run sound to my mixer and my on board sound card for my Headphones.
when I DJ for a certain length of time the screen freezes. The music works perfectly but I cant change anything on the screen. Its very annoying. Any Ideas???
Memory Size 1024 mb
VISTA Home
geposted Tue 27 Mar 07 @ 5:10 pm
many many many topics on this issue....Im not sure where to start, but there has been LOADS of tech talk on this, Im not certain the answer is a quick one.....do some searching here and you will see what Im talking about....
I use a Dell, it used to freeze on me but then I did some tweeking, as discussed in the forums and got myself a Laptop Chill pad to relieve the heat build up.....now its fine, no freezing...
Good Luck...its a hot topic here!!!
geposted Tue 27 Mar 07 @ 7:27 pm
Hi,
i used to have all sorts of problems ( screen going blank , freezing etc. Dac 3 not working) and all tweekings didn't make any difference . In the end i re-installed windows and now it is fine , no problems at all .
geposted Tue 27 Mar 07 @ 8:28 pm
