Topic: 4.3 is out - Page: 2
Also they have add in the remote control confiq numark's icdx, dmc2 and of course total control
so the only think that we are waiting now is total control in the stores :)
To start:
1 the bug with the end of the timecode signal was corrected
2 And new for VDJ V4.3 Clear Database.
Is there any timescale for the history file to be posted ?
Bugs Corrected
* end of timecode bug fixed, stops track
* Long files crash bug fixed
* mk2 now works under Vista
* various dmc-2 fixes
* automix bug partly fixed (Works better now)
New Features
* Clear Database (Local Database)
* tag read for bpm
* First Mac Release
note: 4.3 doesn't really have much new, as the main development have been around the MAC version of VDJ
4.4 will bring some new features and major changes, work have started on that:)
Thanks to the team for the update! :)
But like somebody else has already said, is there a situation where I would want to clear my database (deleting all the bpms and cue points, etc that i made)?
it dosnt effect the bpms or your cue points,they are stored in a different place.
it is more of a feature for removing tracks that you have deleted or moved from the HDD.
DJ FORMAT
To clarify the 'Clear Database' -- there are 2 key files that store information about your tracks. 1 is the XML file (VirtualDJ Database (name).xml) that holds the BPM, CUEs and alike. The 2nd is the text file (mp3database.txt) that holds simply the list of tracks and their path locations. This text file is what is used to populate the browser when you click on the 'Local Database' in the navigation tree.
It is very combersome to go in and delete the mp3database.txt file then go to VDJ and scan. The Dev Team added a simple feature that clears that mp3database.txt file to that you don't have to go through that hassle and then immediately rescan you system to rebuild the database list.
Hope that helps all that are concerned with 'deleting' there info.
Not to be a pain. But if I delete files off my hard drive then rescan my local database won't it do the same thing as clearing my database?
Can someone please tell me how to set exit points using automix? I can not seem to set proper exit points in a song.
Thanks.
Thanks for the explaination about the clear database feature, could come in handy. :)
dj-in-norway:
when you say automix fixed (partly) exactly what do you mean?
Will it mix them and not go part way into the song and will it play all and not randomly
delete tunes from playlist>
Havent tested yet, so not sure how fixed the automix is.
I just know that its not fully fixed yet, so anyone please try and see if it works better now :)
dj-in-norway:
Thanks will give it another try
skyfxl
You say if using ver 3 do a full installl.
Will that overwrite ver 3.4 or will you have 2 versions on the system?
If you make a copy of previous version EXE file and rename it, before you install the upgrade, you can have and use previous versions.
Rename it like this for example
- VirtualDJ_3.4.exe
- VirtualDJ_4.2.exe
etc
That way you can have several exe files, that starts its own version of VDJ ;)
;) nice
i've been @ the hideous club, so i only had limited opportunity to go spelunking in the software , in fact i'm there now ....i like the text resizer doodad .....
@ bogart ....i thought it did that.....a track would go away ........i'd either accuse myself or wonder if it was caused by especially good corona ........
confirmed: When the timecode signal ends, the music still plays- tested using SMART MODE.
Excellent-
Nor- there were no updates to midi functions (i.e. able to control more video parameters) yet were there?
t/u
B
4.4... and it will come pretty quick now.
Please remember that 4.3 is almost only a mac release, with a few fixes for the PC too.
But almost all the effort was made into making VDJ work on MAC, and thats quite some work
thanks-
chucknorrisyouwimps
Yep it definetly just deletes some tunes from the list; or at least did.
There was another thread about automix where this was already stated.
My contention is that I am going to use the pgm totally. That is let's say
Cocktail hour, Dinner Hour (where you need automix) and throughout the
rest of the evening. Ver. 3.4 did that for me very well and that's why I keep using 3.4
and took 4.2 off mys system.
Not knocking the pgm by any means. But 3.4 works perfectly for me and until I can be
sure that 4.3 will do the same I will not install it on my gig system.
I have to try 4.3 out to see how it goes.
62%
