Can anyone tell me what is the best sound card for timecoding cd's. I would like to know as far as sound quality and features which one is the best. I have a Presonus Firestudio (very expensive) but I can't seem to get it to work right with VDJ.
geposted Wed 28 Mar 07 @ 7:31 pm
Timecode soundcards
USB card that work good :
- NUMARK VIRTUAL VINYL
- Maya44 usb
- U46DJ
- Edirol UA-1000
and more
Firewire cards that work good:
- Prosonious Firebox
- Shaffire Le
- Edirol FA-66 , FA-101 and more
- Digidesign Digi 002 Rack
- Ego-Sys QuataFire 610
- Hercules 16/12 FW
- M-Audio FireWire 1814
- Terratec Phase 88 Rack FW
and more
PCI cards that works good :
- Delta 44 & 66, Delta 1010LT & 1010
- Soundblater X-FI platinum or elite
- Mayy 44 PCI
- Maya 1010
- Sound Blaster Audigy 2 ZS Platinium Pro
- Sound Blaster Audigy 4 Pro
- Echo Layla 3G
- Ego-Sys ESP1010
- Ego-Sys WaveTerminal 192M
- Soundblaster E-MU 1820, 1820M
- Marian Marc 4 MIDI
and lots more
PCMCIA cards that works good
- Soundblaster E-MU 1616M
- RME Audio Hammerfall DSP System
Generally speaking, almost any card that has two line ins in STEREO, and two line outs, will work, and if it has ASIO drivers its likely to work good (low latency drivers).
Those listed above are PRO cards, so some are damn expensive..
But get a card thats not the most expensive, but not the cheapest eather.
Soundblaster is a good solution on budget.
you need a card with asio and low latency generally speaking
geposted Wed 28 Mar 07 @ 9:28 pm
and Serato's Scratch Live's SL-1 usb box
geposted Fri 30 Mar 07 @ 2:15 pm
how do u set up the u46dj sound card i have but cant seem to configure it..... please help tryed to update the driver buy nothing....thank you.
geposted Fri 29 Oct 10 @ 11:22 am
