I am using Ccue and a laptop with a usb Maya 44....
I would like to set-up so that when I all of the audio go to Channel one ports 1 & 2 from both decks A & B and channels for head phones... what I want to do is to be able to use the auto mix feature in cue tp play music and whan I want to use the other channels to listen via Headphones to cue something up....
Is this possible? How do I switch a Deck to only be heard through Headphones... I hope this makes sense...
Thanks
Burt
Thanks
Burt
geposted Tue 03 Apr 07 @ 10:03 pm
Yeah, it is possible to do, but what you need is an adaptor that has two rca plugs on one end and a mini jack socket on the other (to plug your headphones into). The headphone socket on the maya can only output everything that's playing through the card, so it's no good for cueing, etc.
To set it up, just plug the adapot into outputs 3 & 4 of the maya. and plug the soundsystem into channels 1&2.
So then you click on "config" in VDJ and go to the soundcard tab. From that choose "headphones" then choose the maya 44 card from the soundcard list. click ok and you should be fine!
geposted Wed 04 Apr 07 @ 1:13 pm
http://www.thomann.de/gb/cordial_cfy_03_ycc.htm
here's a link to the sort of adaptor you'd need. :)
geposted Wed 04 Apr 07 @ 1:21 pm
