i use the M- audio connectiv program o i can sink up with vinal or cd's . .
it works fine on old crapy PC . . now i baught a killer mac book and am havinh a ton of problems with it . .
it is giving me a sound card error when i try to switch it over in configure . .
i dont know what to do cause i really like virtual dj but if i cant run it on this machine i really dont want it !
i already reinstalled the drivers for the conectiv
now what i am thinkin is i need a diff version of Virtual dj
cause the program conectiv recomends is torq which i dont like at all but .. i got it any ways..
but when i down loaded torq i had to get a beta version of it so it would reconize the m- audio connective
any ideas ????
any ideas ????
geposted Thu 19 Apr 07 @ 7:30 pm
all mac sound cards can be used as output
but currently only numark virtual vinyl supported for timecodes
geposted Thu 19 Apr 07 @ 7:35 pm
I use connectiv with a macbook pro and vdj no problems. torq DOES suck. But connectiv just worked right up front for me with VDJ. I did not uninstall torq. Don't know if that helps or is a reason.
geposted Thu 19 Apr 07 @ 11:24 pm
HMMM thats crazy ! !
see i keep running into problems when i go to configure it . . . it say error in sound driver . . and it only reconizes conective when its not in the time code mode . .
it promps me for virtual vinal ????
its driving me crazy cause i want this program bad ! ! any other ideas. .
is there a order when i should install the m audio driver befor or after virtual dj ???
if any one has any ideas please help me out.
or im gonna have to buy numark virtual vinal for its interface ! !
thanks alot
D
thanks alot
D
geposted Fri 20 Apr 07 @ 12:02 am
I had it installed before the Mac VDJ was available. When I installed VDJ it just worked . I don't use time code, so I'm not sure about that. I just mix for parties and weddings out here in the country. sorry, not much help.
geposted Mon 23 Apr 07 @ 11:59 am
I have a torq connectiv hooked up to my VDJ but its not configured correctly the pitch is much fast. help please
geposted Sun 07 Dec 08 @ 9:26 am
hi all
I'm having a massive problem with connecting torq with pioneer CDj 2000.
I use macbook pro, VDJ 6 and Pioneer CDJ 2000 witch TORQ timecode CD's
I searched all the posts and nothing seems to work. Can anyone tell me what is the correct configuration.
I even tryed to hook up my macbook direcly to CDJ 2000 via USB cable but I only one deck worked well.
i couldn't separate lines on my pioneer 800 mixer to mix the tracks. (all two lines form my torq appeared together on one line)
i would be very thankful if anyone form VDJ crew would kindy direct me to any link where I can find proper configuration.
Thanks!
Thanks!
geposted Sun 24 Apr 11 @ 8:06 pm
OK guys here is what you need to do. Go into configuration and sound set up. Then go into Time code Configure. Look there and you will find a list of different time codes and adjustments. Adjust until playback is correct for you. As far as the sound card error message, make sure that the Sound card option is on M-audio connectiv, not built in sound card. I hope this helps!
geposted Tue 26 Apr 11 @ 7:25 pm
