Other DJ software that people use in a station I play at can set the stream URL/AIM/IRC info to point to whatever the server administrator wishes and thus it's now mandated to set those.
I tried to look how to set these, the default points to virtualdj.com and there's no setting to put my name on AIM/IRC so it would show up in SHOUTcast D.N.A.S. Status (and server logs).
I believe this to be a bug since other software allows to set those and VDJ doesn't seem to even though they are part of the protocol.
If it's not possible to give these a setting in VDJ config, please atleast add a windows registry option so I can use registry editor to set these:
* icy-pub is basically a switch to either allow the server to publish itself in the directory or not (1 meaning yes and 0 meaning no)
* icy-url is the homepage for the stream
* icy-irc is yp shoutcast specific (used for contact information)
* icy-icq is yp shoutcast specific (used for contact information)
* icy-aim is yp shoutcast specific (used for contact information)
If there's already setting for all of these then cool but I didn't find it.
geposted Thu 26 Apr 07 @ 9:00 pm
